DASYLab
measurment computing newer version has to be removed - how to remove for new install
trying to load measurement computing package with V12 - asV13 would not work - error message remove new package before installing V12 package - how do I remove V13 package ?
(5,467 Views)
If you installed through the Configurator, disable the V13 driver.
If you installed through the Add/Remove Programs, use Programs and Features/Uninstall to remove the Measurement Computing DASYLab driver.
Note that the V13 driver may have made a change that doesn't get uninstalled. You may need to call in for support to go back correctly.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(5,463 Views)
