DASYLab
modules are shown on the screen during worksheet loading
Hi. I'm using DASYLAb 13 on a windows 7 machine. Is there a way to prevent the DASYLAB modules to show on the screen during the worksheet loading? For very big programs the worksheet take some time to load. As a result, you observe the modules being loaded. Is there a way to show an image on the PC monitor while the worksheetit is loading?
Regards
(3,651 Views)
Accepted by topic author mneto01
You can configure the display modules to be hidden, using the View menu option "All Windows --> Hide". There is a short cut button on the function bar under the menus.
Otherwise, as the worksheet loads the modules each set themselves up and may flash as they do but will disappear once they are loaded.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(3,615 Views)
