DASYLab
monitor global variables
If you do a ctrl left click you can monitor the data in a wire real time while a DL program is running.  Is there a way to monitor a global variable similarly in real time?
(3,895 Views)
Hi Jim,
You can always open the Global Variable settings at runtime.
You can also configure one or more variables to display them in a window at runtime.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(3,876 Views)
Hi CJ,
I am more looking for something for troubleshooting.  It's really useful to use the ctrl click on a wire to see how a value is changing as is moves from module to module.  When the value does something unexpected, say at a formula interpreter, and the formula uses a GV that you know is actively changed by another part of the program, the static GV table isn't of much use.
(3,858 Views)
