DASYLab
plotting the dependance of two signals continously
Hi!
I would like to continously display two signals, one dependant of the other. Already tried using xy display module, but it can only display data for some limited time. What else can I use?
Thanks in advance for suggestions!
Greets, Vida
(6,552 Views)
Please see the new DIAGRAM module (V10) to plot two channels against each other.
Also, in the X/Y Chart, did you see that you can increase the number of plots in the main dialog box?
Delete after — Specifies that DASYLab deletes the curves after the specified number of data blocks and then starts plotting the curves again.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,548 Views)
