DASYLab
standard saving path with runtime version
Accepted by topic author Hilby
Do not edit the dasylab.ini when using a runtime. Instead, edit the dfs.ini (same location).
BTW: Do not use a fixed path in the Data write module, e.g. C:\Data\myfile.ddf, if the worksheet should run on a RT with changed default folders. Use the "combi"-setting: ${DATA_FOLDER}\myfile.ddf
The variable "Datafolder" will expand to the directory-setting in the dasylab.ini/dfs.ini.
M.Sc. Holger Wons | measX GmbH&Co. KG, Mönchengladbach, Germany | DASYLab, DIAdem, LabView --- Support, Projects, Training | Platinum NI Alliance Partner | www.measx.com
Message 11 of 13
(3,342 Views)
Yeay!!
I am sure that this is my problem!
I used fixed pathes in my data module. I have no possibility to check this this weekend, but I will try that on monday.
I am wondering why I did not see that mistake.
Thanks a lot for the great help!
Have a nice weekend and I will tell you if that was my problem on monday.
Bye!
Message 12 of 13
(3,331 Views)
Hello cj, hello hw70!
My problem is solved, thanks for the help!
Hilby
Message 13 of 13
(3,298 Views)
