DASYLab
voltage is seperated to BNC connector
I use BNC 2110 adaptor, AT-MIO-16E-2 and Dasylab
if I send output signal (voltage) to BNC2110 the signal seperate to two BNC connector
; if I send  5 volt to BNC 2110(AO0) I have to touch AO0(+) and AO1(+) to get the 5V and If I touch AO0(+) and AO0(-) I just get 2.5V(a half of the voltage I sent)
I tried using another BNC2110 but that doesn't make any difference
I've also reinstalled dasylab.
(7,051 Views)
Hi son,
Welcome to the forums! A couple of questions. Have you configured the reference voltages and the polarity of the analog output properly? This is explained on page 3-13 of the AT E Series User Manual.
Second, what version of the DAQ driver are you working with? Do you have Measurement and Automation Explorer on your computer, where you can run a test panel for you DAQ card and check the analog output? Measurement and Automation Explorer would  be under Programs» National Instruments» Measurement and Automation Explorer.
Regards, Mallori Martin
Mallori M
Sr Group Manager, Education Services
ni.com/training
(7,033 Views)
