DATA AHEAD toolkit support Discussions
How to write single bit without overwrite other bits in one writing operation
Is it possible to write a single bit only without overwriting other bits in one byte DB?
(3,808 Views)
currently this is only possible in SP7 by first reading one byte of the DB, then changing the bit your want to set, and finally writing an array of bits to the DB.
Adding a function that will write only one bit is on our list of things to implement for the next version of SP7.
DATA AHEAD
Kudos are welcome...
(3,733 Views)
