DATA AHEAD toolkit support Discussions
Read Only Access
If I try to read a file that is already opened in Excel, I got an error 5001.  Closing Excel fixes this, but is there a way to perform an open operation in a read-only mode, even if it is being accessed by another program?  At the moment the solution would be to copy the file to a temporary location, then read the temporary copy.  This solution works but can a read-only access be done that makes this work without the temporary copy work around?
(4,777 Views)
Hey Hooovahh,
thanks for your suggestion. Creating a temporary copy is definitely a good workaround, for now!
I just checked and it should be possible to allow read-only access to any file in the next version of XLR8 (2.1). Once we implemented it and tested it, I will let you know.
Peter
CLD | Alliance Partner | Web data storage and visualization | daq.io
(4,199 Views)
Just an FYI but I found that a similar issue exists if the file is read-only, and not just already opened by Excel.  So my solution now is to try to open the file, if error 5001 then copy the file to a temp location, set it to not read-only, and then try to open that file.
(4,199 Views)
Thanks Hooovahh!
We appreciate your input. Read-only access has been added to our code and will be available in V2.1.
Regards
Peter
(4,199 Views)
