DATA AHEAD toolkit support Discussions
SP7 RECONNECT
Hello
I am communicating a cRIO with a siemens PLC using SP7 toolkit correctly.
When a hardware change is done in the PLC or for some reason the PLC is stopped, the communication between them is broken and i have to restart also the cRIO.
There is any way to reconnect automatically the connection when it is lost?
Regards
Image and video hosting by TinyPic
<script type="text/javascript" async src="//cdn.youracclaim.com/assets/utilities/embed.js"></script>
(1,918 Views)
that is a standard question for all instrument communications and the standard answer is usually the same:
You have to react to the communication error in your program code and decide for yourself how and when you put a reconnection trial inside your program.
There is no method in the SP7 API that does such a reconnect for you automatically.
DATA AHEAD
Kudos are welcome...
(1,898 Views)
