DATA AHEAD toolkit support Discussions
SP7-S71200 Programming Structure
I have S7-1200 PLC and SP7 toolkit. I am using the structure which is in the photo. I am wondering how can i make this structure more basic and faster. Thanks for advices already. Have a good day.2020-06-25_22-46-12.png
(4,067 Views)
Hello tabatu,
sorry for the late reply.
Talk to your PLC programmer - define your DBs in such a way that you can read or write several values with one Read- or Write-VI.
Setting your voltage and current could be merged into one write-DB, if the variables are defined after each other inside the DB.
I usually like to create one DB for data that goes from PLC->LabVIEW and another DB for data LabVIEW -> PLC. Makes it easier to debug on both sides.
Regards
DATA AHEAD
Kudos are welcome...
(3,834 Views)
