DATA AHEAD toolkit support Discussions
XLR8 Deployment Considerations
If you want to deploy an application built with the XLR8 components, please consider the following:
- Your target PC needs to have the Microsoft .NET Runtime 2.0 or newer installed
- .NET 4.0 does not contain .NET 2.0. Therefore, on Windows XP make sure to install .NET 3.5 alongside, which includes .NET 2.0. Newer OSes have .NET 2.0 installed.
- The target PC should have Windows XP SP3 installed or run on Windows 7 or 8.
- You supply the LabVIEW application along with all dependencies. Ideally, build an installer from LabVIEW
- If you do not wish to build an installer, please make sure to supply the library files of this folder with the Application.exe: "C:\Program Files (x86)\National Instruments\LabVIEW xxxx\vi.lib\DATA AHEAD\XLR8\lib"
CLD | Alliance Partner | Web data storage and visualization | daq.io
Message 1 of 1
(4,337 Views)
