DATA AHEAD toolkit support Discussions
XLR8: formulas disappear in xlsx template file
I read a xlsx template file with formulas. When I add data about a different sheet and save the file with a different name so the formulas have disappeared this new file. How can I fix this?
(5,815 Views)
In template file formula was =IF(MeasuringData!B2;MeasuringData!B2;""). This removes the formula in saved files if value is empty.
Formula =MeasuringData!B2 work ok. But now empty value are 0.0.
(4,702 Views)
Hello IIkka72,
i tried to reproduce your problem exactly how you descriped and i see the problem in the format .xlsx!
A current workaround would be to use the .xls format which works but i don´t know if you are able to use it!
I will have to investigate this problem!
Thanks for your Feedback!
Greetings,
Hajo
(4,702 Views)
