DATA AHEAD toolkit support Discussions
XLR8: wipe sheet don't remove pictures
Picture created with XLR8 "Insert Image.vi".
Solution:
- add a delete pictures VI
(5,355 Views)
Hello daniel,
thanks for your interest!
Currently it isn´t possible to delete inserted images but we will take it to our feature list and discuss it internaly.
Workaround: Delete sheet and create a new sheet with the same name as the old.
Greetings Hajo
(4,699 Views)
Dear Hajo,
I did already the workaround.
Then old named range stay in the file, as mentioned in other discussion.
Daniel
(4,699 Views)
hi daniel,
i answered the discussion you were refering to.
hi daniel,
thanks for reporting that bug! I checked it with the old xls format and you are right! The xlsx format doesn´t have this bug. It will be fixed for xls in the next version of XLR8!
Greetings
Hajo
Greetings,
Hajo
(4,699 Views)
