I find 4D plots very useful in LabVIEW, for example for displaying how sound pressure varies across a 3D surface.
It would be very helpful if DIAdem could do the same.
We added the coloring of a curve (2D axis system) and 3D curves (3D axis system) depending on the values of channel. You can define this in the pallet definition for the line color. This is a new feature of DIAdem 2018.
Greetings
Walter
