It would be very useful to have the ability to use the X-Channel properties in a chart legend as a default option. In the instance of plotting several stress-strain curves on one chart where the Y-Channel (Stress) is shared across different strain (X) channels, there is no easy way of using the legend to show information from the X-Channel.
There are several ways to get X-Channel data in the legend but these methods only get data from the X-Channel of your first or last curve in the chart and uses that same info in the legend for all curves.
Thank you!
Hello
Thank you for your request. We understand your suggestion but given the age of this entry and the fact that just a few sponsors are supporting it, we have decided to decline this suggestion and prefer to develop more frequently requested features instead. We hope you understand this.
Greetings
Walter
