The script editor needs the ability to comment or uncomment an entire block of text at once, similar to what is present in the Dialog Editor and most other script editors.
Hi Daklu,
DIAdem 2012 shipped with these keyboard control sequences to block comment/uncomment VBScript code in the SCRIPT panel.
Brad TUrpin
DIAdem Product Support Engineer
