See comments below.
I love the new buttons on the data portal in DIAdem 2017 (delete, save, save as) but I'd like an "open" button too!
Hi Julia,
Bear in mind that this new icon bar above the Data Portal is user configurable, so you can add (or remove) any icons you want.
Write me an email if you want to see an example.
Brad Turpin
DIAdem Product Support Engineer
brad.turpin@ni.com
Thanks Brad,
I had that thought, and will probably add an "open" icon. I'm thankful for all of the DIAdem icons included in DIAdem 2017 😄
Julia
See comments below.
