Since DIAdem 2018, the number of 5 worker objects has been restricted to 5. This is a difficult limitation for those who are enjoying the use of unlimited worker objects in earlier versions of DIAdem, and do not want to purchase the Analysis Server.
Hello Julia,
Thank you for your suggestion. Because we had technical problems in some cases with more than 5 Workers in the past, we decided not the extend the number of Workers.
Greetings
Walter
