I'd like an option for the tabs on the SUD dialog control, TabPageCtrl, to allow vertical placement, so the tabs would be on the left (or right) side of the tab control.
OK, this is an argument. Your requestis included in feature planning discussions for future DIAdem versions.
Greetings
Walter
