While looking at data I will often want to know the mean average of a section of data (max and min are also nice to see). It would be fantastic if in VIEW mode, you could highlight a section of data (by flagging it) and see in some area of VIEW (like the "Common Properties" section or maybe even a pop-up) statistics of the selected data without having to copy the flagged data and do an analysis of it. This function would go really nice in the drop-down area where you can choose to copy, move or interpolate the flagged data points.
Thank you for your request.
We implemented an example for such calculations. Please have a look at the following example:
"Extending Functionalities with Scripts" -> "Dynamic Display of Statistical Characteristic Values in DIAdem VIEW"
Greetings
Walter
