DIAdem Idea Exchange
James_McN
Change Hex Display Prefix from $ to 0x
Status: Completed
This feature was just released with DIAdem 2012. You could use the format instruction 'str' to do the following: Use '$' to display numeric values in hexadecimal format. If more characters follow after the first $ character, DIAdem uses this character as the prefix for the result, for example: Call MsgBoxDisp(str(1234,"$0x")) ' => 0x04D2 If further $ characters follow after the prefix, these characters indicate the number of places. DIAdem interprets all characters behind the last $ character as postfix, for example: Call MsgBoxDisp(str(1234,"$ $$$$$$$$hex")) ' => 000004D2hex If no further character follows after the first $ character, DIAdem shows the number to be formatted as a hexadecimal value and uses the $ character before the numbers as ID for the hexadecimal display: Call MsgBoxDisp(str(1234,"$")) ' => $04D2
The DIAdem prefix for hex data is $ and as I am aware you must use this.  Most programs use the prefix 0x.  There should be an option to chose one, the other or none.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
3 Comments
Brad_Turpin
Trusted Enthusiast
Hi James,
You are absolutely correct.  The "0x" syntax is the dominant one I see everywhere.  DIAdem should indeed consider this.
Thanks for submitting your idea,
Brad Turpin
DIAdem Product Support Engineer
Otmar
Active Participant
Status changed to: Under Consideration
Otmar D. Foehner
dietfons
NI Employee (retired)
Status changed to: Completed
