I do not understand why it is not possible jet. After I Drag and Drop a Waveform inside VIEW. A possibility to change the x-Axis to absolute time should be possible.
The only way of doing it now is creating an extra Time Channel.
This request was implemented in DIAdem 2019.
Greetings
Walter
