It´s boring and annoying to open a Datafile and the Report-File manually.
When I open a Datafile and change to Report, then the Fileopen-Button opens a complete different directory and i have to click (many clicks!) to the destination where the Datafile was loaded from.
Please improve this!
Hello Pieczarek,
This function is already implemented. It is up to you how to synchronize the file folders for the different DIAdem modules. Please have a look at the menu “Settings” – “DIAdem Settings” and there at “Select path” and the help on this page.
Greetings
Walter
