Hi
I know right now you can create a coordinate object in a 2D plot and set the values or create a constant line. Now I would like to create a line that would have the same behavior as the coordinate, just making the input of the initial and final points. I know it is posible to do it creating 2 channels in the data portal but I would like to have the line embedded in the 2D-Plot just like the constant and coordinate objects.
Thank You
Hello
Thank you for your request. We understand your suggestion but given the age of this entry and the fact that just a few sponsors are supporting it, we have decided to decline this suggestion and prefer to develop more frequently requested features instead. We hope you understand this.
Greetings
Walter
