Create a version of Diadem that has no user interface. This version would merely run scripts for use in delivered custom solutions.
Hi Jim,
With the shift towards server side processing, this request is unlikely to ever occur with DIAdem the desktop software. NI's Analysis Server is able to respond to REST api calls from custom user interfaces and run analysis and create reports on the server, close to the data.
Brad Turpin
DIAdem Product Support Engineer
