Currently the data type of group properties is automatically set, when two colums are used, one for "Name" and one for "Value". (see picture, right side)
I recommend to enable the possibility to manually set the data type for every individual entry, regardless which column is chosen for Name and/or Value.
Released/Fixed with DIAdem 2015
