Not sure if feature already exists but it would be great to be able to double click (Or similar action) on a view area to then have that area explode to the full size of the screen. When comparing several data items it is often hard to see data exactly and a separate tab with individual displays is often needed.
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions. But because of the huge numbers of possible DIAdem extensions and the fact that just no sponsor is supporting it, we gave this request a very low priority.
Greetings
Walter
