This idea is borrowed from other programmers editors where you can select a sub-routine name or function name and then right click on this name to jump to where it is defined. The path to search for could be based on the currently open scripts within Diadem Script editor or it could be extended to all user commands currently loaded.
Hello
Thank you for your request. We understand your suggestion but given the age of this entry and the fact that just a few sponsors are supporting it, we have decided to decline this suggestion and prefer to develop more frequently requested features instead. We hope you understand this.
Greetings
Walter
