Please include commands to handle INI Files (like CVI)
at the moment we have to handle and search for goups completle manual
it would be much more easier to get 1 command to geht the Value from "test"
[exam]
test = 3
Thank you for your request.
Searching for files or searching within data, you can use the DataFinder. This makes a INI file obsolete.
Greetings
Walter
