In some cases, the visual interface becomes very confusing and mixed up. Is it possible to develop a function to form layers like in the dialog editor?
It would simplify the work in complex dac plans very much.
Thank you for your suggestion.
For a better handling at design time you can use different layer for data-, system-, etc. connection line. In VISUAL you can define your own page layer (menu View) which can be selected in any display instrument (general layout).
Greetings
Walter
