DIAdem Idea Exchange
RussellSenior
More information in the help file regarding OpenDataStoreByParameter for Display
Status: Under Consideration
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions.
Greetings
Walter
In the help file, there is little information about formatting the XML text string for opening a data store by parameter. Specifically, how to enter the password field.  When you use ctrl-shift copy to get the data from the data store dialog box, the password field has <pwd s=""1"" c=""1""> and an encrypted password.  If I want to use plain text, I have to use <pwd e=""1"" c=""0"">.  The only way I could find this information was by searching other ODS functions, specifically: function ODS_CreateAidMap.  There is an example in there.
Anyway, more information on setting up the XML string would be handy.
Thanks.
2 Comments
AndreasK
Active Participant
Have a look at
"C:\ProgramData\National Instruments\Shared\USI\Plugins\DataPlugins\AOP5_64\uspAOP5.html"
that describes the parameter string in detail.
in the newest version of the AOP% plugin this html file is opened if Help button is pressed in AOP5 advanced options.
Walter_Rick
NI Employee (retired)
Status changed to: Under Consideration
Hello
Greetings
Walter
