Please, is it possible to increase the number of serial - COM ports in DIAdem 2018?
Please, is it possible to increase the Baudrate of the COM ports in DIAdem 2018?
If you use the DAC script driver and within this the UDI interface, you can use any COM device. Only in the old “Serial interface (COM) …” which is a small tool to send or monitor COM you have COM 1 up to COM 9.This is supported since DIAdem 2015.
Greetings
Walter
