I work with a lot of data that contains true/false parameters. I spend a good amount of time converting these channels to 0's and 1's in order to plot them with other numerical parameters. Excel will automatically plot true/false parameters as 0's and 1's, but I prefer to use DIAdem. It would be very helpful if DIAdem could plot these without converting them.
That’s a good point, Brad. Hopefully is helps with an easier handling of true/false channels.
I will turn back the status to declined, because that’s our current decision.
By the way, declining a suggestion doesn’t mean not developing it in the future. It only says not developing it in the next two or three versions. The suggestion is still on our internal list of further feature options.
Greetings
Walter
