I would like to have a option to set default properties.
For example: I need default 0.7 curve width, change default color scheme for axis system, etc. On dialog boxes should be a Set as default button.
I would like to change multiple curve properties at once.
Means to select several curves and switch display mode to spikes, or set another line style, etc.
Hello
Thank you for your request. We understand your suggestion but given the age of this entry and the fact that just a few sponsors are supporting it, we have decided to decline this suggestion and prefer to develop more frequently requested features instead. We hope you understand this.
Greetings
Walter
