When editing a Script. The path for the saving files defaults to the last opened file, instead of remembering the path for each file being editted. This causes files to be saved in the directory of the last file opened, which many times results in the wrong saving location. This is especially an issue when have large number of script files in different directories.
I would prefer that each script file that was being edited would keep it path separate and stored so that it always saves the files to the location that it was opened from.
This was implemented at least since DIAdem 2015.
Greetings
Walter
