Changing the order of opened scripts (tabs) manually would be awesome feature. Now its a bit frustrating when u got scripts in different folders and you would like to change the order when you work on more than one script.
Hello
Thank you for your request. R&D has read this suggestion and it will be included in feature planning discussions for future DIAdem versions.
Greetings
Walter
