DIAdem Idea Exchange
DieselPower
Threaded Loading into the Data Portal so I can Work While Data is Loading
Status: Completed
This was implemented for DIAdem 2015.
In the DIAdem settings for NAVIGATOR -> Loading behavior you find the configuration for it.
Greetings
Walter
Title says it all.  I don't like waiting while files load.  Can this process be threaded?
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
15 Comments
DieselPower
Active Participant
It is.  I used the Create Data Plugin Function so I could load files without using the wizard every time.  I didn't manually edit anything in the script.
Brad_Turpin
Trusted Enthusiast
Hi there,
DIAdem 2011 should load your 60 column ASCII file several times faster than DIAdem 2010 or earlier versions.  If you do not see significant speed increases-- perhaps as much as 5x, then we should take a closer look at that DataPlugin.  The ASCII file format you describe should load MUCH faster in DIAdem 2011.
Brad Turpin
DIAdem Product Support Engineer
DieselPower
Active Participant
I will upgrade as soon as they will let me.
DieselPower
Active Participant
We upgraded and it certainly loads faster.  Thanks!
Walter_Rick
NI Employee (retired)
Status changed to: Completed
Greetings
Walter
