Hello panta1978,
Thank you for your feedback. We have discussed your suggestions with R&D and have come to the following conclusions.
1) With DIAdem we install an example which rearrange the left side of a 2D axis system depending on the range of value (and thus on the number of digits) so that the Y axis are aligned to each other.
We have extended this example so that now also the right side – the width of the legend – can be aligned. We will install this example with the next DIAdem Version. Attached is a preview version of it. If you would like to test is, copy all files into the folder “…\DIAdem\Examples\Documents\” folder.
You can run it here:
Then you get these tools in addition:
This change of the tool bar can be stored together with the desktop of DIAdem.
2) and 3) Yes, we understand your perspective and yes, we could have implemented it the way you suggested. And I can still remember the time when we discussed how to implement these functions.
We decided at this time to implement this functionality as it is, and since this implementation is more than 5 years old, we do not want to confuse our customers and stay with it as it is.
4) Manually defining the X range (time range) is already implemented. You can edit the corresponding values of the Coordinates window.
Greetings
Walter
Hello panta1978,
You can run it then here:
Greetings
Walter
Hello panta1978,
Greetings
Walter
Hello panta1978,
Greetings
Walter
