Use Case: We frequently use the 'Report' panel of DIAdem, where the 'Transfer-To-View' function is essential. Typically, we include 4-5 graphs on a single 2D axes system.
After transferring the page to the 'View' panel, we receive the correct image but with multiple areas worksheet
Problem Statement: When zooming the x-axis, each area zooms independently, which is inconvenient when analyzing data from multiple graphs simultaneously.
Proposed Feature:
Combined Area Zoom: Create a feature that combines multiple areas (e.g., 4 areas) into a single area. This would enable synchronized zooming of all areas while preserving individual graph characteristics.
Synchronized Zoom Across Multiple Areas: An alternative would be to implement a zoom synchronization function for the x-axis that works across all individual areas without merging them into one.
