DIAdem
2019 - Changing the order of tabs/opened script in Script panel
I asked 3 years ago if you can make possible changing order of opened scripts in Script panel. I just installed Diadem 2019 and i see that u changed the place for this tabs from bottom to top of the script window, but still i cant change the order. Will you ever make this feature? Because it will be really very usefull and stress eliminating.
here is the thread i asked for the feature: https://forums.ni.com/t5/DIAdem/Scripts-panel-moving-with-tabs-sheets-of-opened-scripts/td-p/3294302...
In most IDEs this feature works, but not in Diadem...
(2,648 Views)
Hi Lukas,
This forum is more focused towards support questions. If you'd like to suggest features, I recommend posting on the Idea Exchange. The Idea Exchange forum is monitored directly by our R&D team, so you can suggest features and get responses from the people with the decision making power on the subject.
Best,
Lindsey Nestor
Program Manager, Hardware Services
(2,591 Views)
Yeah, <Sigh>
I also would love to be able to rearrange the opened tabs in DIAdem SCRIPT.
Sorry, not yet,
Brad Turpin
DIAdem Product Support Engineer
(2,535 Views)
Hi guys,
The idea that Lukas had got me thinking, that maybe this was possible.
Was able to make a vbs class that allow me to either load up in script editor all the vbs files in a path.
Or lets me load up the editor with files that are listed in file. Kind of like a project, The order exactly the same each time.
This can be linked to a Button in Script pane so could have a different button for each project where it will setup the editor.
Anyway take look and see what you think.
Paul
ps. I can see other functions that would help script writing efficiency will see where I go from here.
(2,496 Views)
