DIAdem
2D Plot Channel Names
I'm having trouble finding a method to extract the name of the channel being used within a plot as the y-axis (ex: [#]/Speed, [#]/Torque). What I'm attempting to do is:
Look if a specific channel exisits
If it does exist add the corresponding mean value channel
If it does not exist move on to the next curve/plot/tab
Message 1 of 17
(4,969 Views)
Are you talking about curves in the VIEW tab?
If so, this code can get you started on accessing different elements in sheets/areas/curves in the VIEW tab.  Just type a period after each element to view a variety of methods/properties.
Option Explicit 'Forces the explicit declaration of all the variables in a script.
Dim Sheet, Area, Curve
For Each Sheet In VIEW.Sheets
For Each Area In Sheet.Areas
For Each Curve In Area.DisplayObj.Curves2D
Call LogfileWrite("Sheet: " & Sheet.Name & " | " & Area.Name & " | Curve:" & Curve.YChannelName)
Message 2 of 17
(4,937 Views)
I will be looking at curves in Report.
Message 3 of 17
(4,928 Views)
You can right click on an element such as a 2D curve plot and select "Copy as Script" and then paste it in the SCRIPT tab it will list out all the elements for you with comments!
Message 4 of 17
(4,924 Views)
From what I can tell this only provides the code to create that element. What I'm trying to do is get the channel name of an element that is already plotted.
Message 5 of 17
(4,922 Views)
That does seem to be oddly complicated to extract... was not able to find a workaround
Message 6 of 17
(4,918 Views)
Hi Brian,
Find attached a test I did. That may not be the best way to do it and you may need some editing but that should work fine.
Feel free to ask if needed 🙂
CLAMaxime -- Kudos are a great way to say thank you
Message 7 of 17
(4,889 Views)
Is there anyway that you can put the scrip in the body of a reply? I cannot download internet files.
Message 8 of 17
(4,869 Views)
Sure !
'-- VBS script file
'-- Created on 05/09/2018 13:37:04
'-- Author:
'-- Comment:
Data.Root.Clear
Call DataFileLoad(CurrentScriptPath & "EXAMPLE.TDM")
Call VIEW.LoadLayout(CurrentScriptPath & "EXAMPLE.TDV")
Dim oSheet : Set oSheet = VIEW.Sheets("Test")
Dim oChart : Set oChart = oSheet.Areas("Chart")
Dim oCurves : Set oCurves = oChart.DisplayObj.Curves2D
Dim oChannels : Set oChannels = Data.Root.ActiveChannelGroup.Channels
Dim channel, oMyCurve, count, name
On Error Resume Next
For Each channel in oChannels
  count = 1
  oCurves.SetLeadingCurve(count)
  While(Err.number = 0)
    name = Split(oCurves.LeadingCurve.YChannelName, "/")
    If(channel.Name = name(1)) Then
      Set oMyCurve = oCurves.Add("[1]/Time", oCurves.LeadingCurve.YChannelName & "_Mean")
      Err.number = 1
    End If
    count = count + 1
  Wend
  Err.Clear
Call VIEW.Refresh
The ZIP also contained a TDM and a TDV but I am sure you can adapt this code to your application 🙂
Note : the code is given as is and that may not be the best way to do it.
Message 9 of 17
(4,866 Views)
I think this scrip will only work in View, I'm working in report.
Message 10 of 17
(4,860 Views)
