DIAdem
2D Tabelle Zellen verbinden
Hallo Forum,
Gibt es eine möglichkeit in einer 2DTabelle im Report z.B. 2 Zellen zu verbinden, also per Script?
(Wie in excel 2 nebeneiandner liegende Zeilen verbinden zu einer)
mfg
(3,811 Views)
Sie können viele gleichmäßig beabstandete Werte zwischen den beiden Punkten einfügen, indem Sie eine for-Schleife verwenden. Vielleicht ein konkretes Beispiel geben? (Ich habe Google Translate verwendet, damit die Kommunikation nicht 100% ist)
you can insert many evenly spaced values in between the two points using a for loop. Maybe provide a specific example? (I used google translate so communication is not 100% here)
(3,783 Views)
Thank you for the response.
Okay for example i want a 2DTable with 2 columns and 20 rows. Is it possible that i can concet (at any row 1-20) 2 cells to one single cell?
In the report i cant conect the cells thats why i looking for a script command.
i have uploaded one screenshot for your better understanding.
(3,777 Views)
Really hastily put but a good start point
Option Explicit  'Forces the explicit declaration of all the variables in a script.
DIM DELIMITER: DELIMITER = " - "
Dim chn1, chn2, resChn, i
Set chn1 = Data.Root.ChannelGroups(1).Channels(1)
Set chn2 = Data.Root.ChannelGroups(1).Channels(2)
Set resChn = Data.Root.ChannelGroups(1).Channels.Add("result", DataTypeChnString)
For i = 1 To chn1.Size Step 1
  resChn.Values(i) = chn1.Values(i) & DELIMITER & chn2.Values(i)
Assume your column 1 and 2 are in group 1 and are the first and second channels in that group.  Can definitely be developed into a more modular function
(3,773 Views)
I dont think you got me right. I dont want to add up(calculate) columns together or something like that. My Problem is more trivial i want just put 2 cells together. So i can write in one cell out of 2 cells summarized. excusme me for my bad explain and english.
Thank you for your help so far.
(3,753 Views)
When running the code above on a file that is exactly like your example picture (file attached), I get a result group as shown in picture (attached).  Change the value of DELIMITER to change the way the columns a joined.  Try running the code on Example File.tdms to see
(3,732 Views)
