DIAdem
2D chart in TDR with different group names
I have a TDR that I would like to use on various data sets.  The channel names will always be the same, but occasionally each channel will be in a different group in the data set.  So lets say data set one, my y-values are "Group_1/Temperature", but in data set two it is "Group_6/Temperature".  Actually, the y-values in this case are simple, just don't use the group when specifying the y-axis for the curve. The problem is the x-values of the curve.  Each group has a time channel in it, each one called "time".  So the x-values from data set one is "Group_1/time" and data set two is "Group_6/time".  Keep in mind "time" is not a unique channel in each data set, as each group has a time channel. So, this means that in data set one, there is "Group_1/time", "Group_2/time"; "Group_3/time", etc.
So, what is the easiest way to make a TDR that will handle this situation.  The main problem is how to specify the correct group for the time channel (x-values)
Any help is appreciated.
(3,950 Views)
Accepted by topic author Mr. Spark Plug
I found a workaround:  Press Ctrl-A whil in script record mode and you have the 2D Axis dialog box open.  This records all the parameters to the script.  I then use this for the x and y channels:
    D2CChnXName      = "[" & ChnGroup(Cno("Temperature")) & "]/time"
    D2CChnYName      = "Temperature"
I have only tested it on a limited basis, but it seems work.
If anyone has a better suggestion, I am all ears.  (I now love Ctrl-A, btw...)
(3,944 Views)
