DIAdem
3D model imported with colored surfaces
I'm importing a .wrl file directly from PRO - E using the VRML plugin. When I import it into the diadem window the model is fine, but each surface is individually colored, and thus when I allocate coordinates the colored plots do not exist. Anyone had any experience with this? Any help will be greatly appreciated!
Dan
(4,824 Views)
Problem solved! Tried the other compatible 3d file (.STL) and no longer do I have this issue. One minor thing for those out there who are into there code writting, does anyone know how to create a script that automatically rotates my model about a set axis, as a designated frequency?
Dan
(4,816 Views)
Hi Dan,
Out of interest what does your model represent in the real world? I may have some scripts which can be adapted to your product which provide the functionality that you have highlighted.
Regards
Matthew
(4,804 Views)
