DIAdem
ATR Format Definition (4 byte real)
Is it possible to define a 4byte real in the read command?  I tried %4BNR but i get a syntax error for that.
READ COM1 "4BNR"
diademi
(5,050 Views)
Hello diademi,
I am sorry to tell you, that the 4 byte real format is not supported by the "ATR" driver in DIAdem. The driver only supports 6 or 8 byte real format.
Rainer
(5,030 Views)
Can i define a custom data format or decrypt somwhere else?
Is that possible with the script-dac-driver? How would the read procedure or the defintion look like?
(5,028 Views)
Hello diademi,
I'm quite sure that the 4 byte real format is not supported by the script-dac-driver either but you may give it a try. If it is not supported, you may read it as a 4 byte integer and split this value into its  mantissa and exponent part. With these two values you should be able to calculate the 'four byte real' value with VBS.
Rainer
(5,022 Views)
Thanks so far RainerH,
do you know if there are some examples available besides these that are in the pdf manual?
 diademi
(4,978 Views)
In the pdf manual is a hole chapter about a software device simulator. Does anybody know where to find this application?
diademi
(4,973 Views)
Hello diademi,
I found the simulator as an additional tool on the DIAdem 8.1 distritbution. I have attached it to this post. I hope it will help you.
Greetings
Rainer
(4,955 Views)
