DIAdem
.AUT autosequence and .VBS autosequence
Is there any solution to start an .AUT autosequence from a .VBS autosequence. Start .AUT from an .AUT autosequency and start .VBS from a .VBS autosecuency works.
Is it true that an .AUT sequence doesn't work in Diadem 9.0 ? If not is it possible to convert it ?
I love Diadem !!
(3,913 Views)
Because AUT and VBS are running in different engines it is not possible. (If you would do this you could have problems with synchronising the autosequences.)
But it is very simple to convert AUT to VBS. If you are in AUTO go to "Autosequence->AUT/VBS Autosequence converter ...".
If converts at least 99% of your AUT and marks the lines which are not clearly like "For L1 := 1 to L2 do" (L2 is for the converter unknown).
I hope this will help you
Walter Rick
(3,913 Views)
.. I like to add that AUT sequences still run in DIAdem 9.0 as they did in DIAdem 8.1
You can run them by "Execute script file" in the toolbar in module SCRIPT. Please select "AUT" as a file type, select the file and just run it !
(3,913 Views)
