DIAdem
AVL Puma ASAM data base on DIAdem
I am using DIAdem 2015 and I like to open the test results from AVL PUMA that are storage on and ASAM data base but I do not know how I need to set it on DIAdem.
I have the user, password and server name of the AVL PUMA data base (with version 3/3.2/5 (RCP) and Santorin Registry: Host15P)
First, I have created a New Data Storage (Image attached 1.JPG). Then, I need to fulfil the information in the next window (image attached 2.JPG).
As I said, I have the Server, User and Password. But, which Connection type, Port and URL I should set?
Diadem version: 2015 x64
AOP5 version: 18.0.0f7090
Thank you very much.
(2,907 Views)
If an RPC connection should be used a 32bit DIAdem is needed.The plugin is called AOP.
You may check if the server also has a CORBA interface running which will also work with DIAdem x64 and the AOP5 plugin.
(2,890 Views)
