DIAdem
Access Violation error with Diadem 2011
Hi Jcheese,
I'm not convinced by your description that you're actually running into the same bug.  Would you please submit data files and a REPORT file so that we can reproduce your error and see if the efforts on the initial bug reported will address what you're running into?
Brad Turpin
DIAdem Product Support Engineer
Message 11 of 19
(2,163 Views)
here are the files I am using.
I have had my hard drive fail and have replaced it but still have the same error message.  Maybe it is something in my script file. So here is all the information I am using including the .CSV file for the report script.
thx - James
Message 12 of 19
(2,162 Views)
Hi Jcheese,
I was able to run your script and export a PDF file successfully in both DIAdem 2010 and DIAdem 2011.  Have you tried this on multiple computers?
Brad Turpin
Message 13 of 19
(2,148 Views)
yes - i have tried on a couple and they do not have a problem either.  Any ideas ?
Message 14 of 19
(2,144 Views)
Hi James,
The fact that I can run your script successfully and you can run it successfully on other computers indicates that the problem is not in your script.  Since the offending action is in the PDF printing process, then I'd suggest we start looking there.  You could try removing the DIAdem PDF printer driver from the Windows "Printers" list-- the next time you launch DIAdem the PDF printer will be registered again.  Perhaps that will help.
Brad Turpin
Message 15 of 19
(2,137 Views)
Hi Brad
I have the same problem and I've just noticed that is because of the fill property of one of the bars. I put a TDM and TDR which shows that
Message 16 of 19
(2,091 Views)
Hi dslemusp,
I tried to reproduce the access violation error, but was unsuccessful. I was able to open the files you attached without any errors. What version of DIAdem are you using and on what operating system?
Rohama K.
Message 17 of 19
(2,059 Views)
Hi Rohama
The Version is 2011. In order to reproduce the error you have to change the fill property to "filled".
Anyway the bug is solved in the 2012 version
Cheers
Message 18 of 19
(2,040 Views)
Hi dslemusp,
I still can't seem to reproduce the error. In DIAdem, I loaded the data into the data portal, opened the report, changed the filling curve parameter for Bar to Filled, clicked OK and can see the change on the report. Glad to hear you aren't having this problem in DIAdem 2012 though.
Rohama K.
Message 19 of 19
(2,026 Views)
