DIAdem
Access Violation
I'm trying to run a fairly large script but I keep getting the same error at a certain point.
Error Type: Access Violation
Error Address: 0000E76E
Module Name: DIACMPNT.DLL
Exception EExternalException in module ntdll.dll at 00075DE3
External Exception C01500F
Once it reaches the spot DIAdem completely locks up and shuts down.  I can run the small block of code where the error occurs separate but when I try to do a full run it crashes.
Any help would be great.
Thanks!
Andy
(4,193 Views)
Hallo Andy,
Thank you for this information. To help you we need some more details.
Which exact DIAdem version do you use? Please have a look at the menu > Help > About. We need all three version numbers (DIAdem, USI and DataFinder)
On which OS is DIAdem installed and running?
Are you be able to locate a certain script area in which the problem occurs?
Can you briefly describe what your script is doing all in all, please?
Feel free to contact me directly ("my first name"."my last name" followed by AT and ni.com)
Greetings
Walter Rick
(4,185 Views)
