DIAdem
Access violation err:00142C50
Hello there,
Has anyone met  with this error before or know what does it mean?
Error while executing "StatBlockCalc" command
Error type: ACCESS VIOLATION
Error address: 00142C50
Module name:GFSFILE.DLL
this error appears quite randomly when i am try to average of a channel. When this appears i just close Diadem and it works afterwards. Do you have any idea why is that?
Thank you very much in advance for any inputs.
(3,234 Views)
Thank you for posting this question. I would like to check up on this post since no one in the community has gotten back to you yet.
Could you possibly the part of your script that is dealing with this channel? Since the code usually works I doubt that this is an issue with your code. Have you tried running the code on another machine? If so, it is possible that your computer's RAM and CPU sometimes reach critically high levels.
Sara N H
(3,208 Views)
Hello there,
This error occurs in the script when it is trying to calculate an average of the channel.
Call StatBlockCalc("Channel","1-","[1]/LC1_SMOOTH")
Yes, i did try to run it on other machine and still i get the error 1 out 10 times. Well it could be the RAM and CPU is there a way how to prevent it from happennig ?
(3,152 Views)
Hey,
What channels are you trying to apply that function to ? Can you send us a TDM with the data so that we can play around with it ?
CLAMaxime -- Kudos are a great way to say thank you
(3,149 Views)
